I tried many times fflush function for sd card , then i saw these codes on internet .These codes belongs to old keil version .
/* * R T L - F l a s h F i l e S y s t e m * * Name: _FS_FLUSHBUF.C * Purpose: Low level File Flush Buffer Function * Rev.: V3.22 * * This code is part of the RealView Run-Time Library. * Copyright (c) 2004-2008 KEIL - An ARM Company. All rights reserved. **/
#include "File_Config.h" int __flushbuf (int handle) { /* Low level file flush function. */ FALLOC alloc; IOB *fcb;
fcb = &_iob[handle]; if (!(fcb->flags & _IOWRT)) { /* File not opened for write */ fcb->flags |= _IOERR; return (-1); } if (fcb->drive == DRV_MCARD) { return (0); . . .
It seems nothing changed since old versions . Fflush has not implemented yet for sd card.
m i right?
Hi I have the same problem .. there is nobody to say something???
