Unable to execute from SDRAM due to incorrect MPU Settings
what should be the settings for MPU if I want to execute code from Internal Flash and external SDRAM in my target
configuration?
Target Map for your reference is as follows,
Internal Flash -> 0x0
External SDRAM -> 0xA1000000
More details:
1. I have modified the scatter file to create two load regions, One LR for Internal flash starting at 0x0 and another LR for external SDRAM starting at 0xA100000
2. I am using emWin graphics library wherein emWin display buffer is using SDRAM memory starting from 0xA0000000
3. I have created two binaries(as there are two load regions) from final .axf file and I have dumped one binary in Internal flash and the other in external SDRAM through a PC utility and a secondary boot loader in my firmware
4. I can see the code in SDRAM during DEBUG mode, but as soon as the control reaches 0xA1000000, the next step lands me in HARDFAULT HANDLER.
I think, the MPU settings are incorrect. If anyone has gone through this ordeal, please point a link or any suggestions would be appreciated.
An HAL
