Hi, i want to use USB host controller on LPC1778 with USB_CM3.lib and usbh_ohci_lpc177x_8x driver. The board is custom and there are no ISP1301. In driver - usbh_ohci_lpc177x_8x i saw functions for working with I2C(ISP1301). When i calling "usbh_init(0)" and "usbh_engine(0)" I2C functions are too calling. Is it possible to modify driver to work without ISP1301 as host only?
Thank's in advance !
Surely, usbh_ohci_lpc177x_8x.c (in C:\Keil\ARM\RL\USB\Drivers\) supposes an external OTG-PHY, controlled over I2C.
It's possible. Start with usbh_ohci_lpc17xx.c, instead of usbh_ohci_lpc177x_8x.c The OHCI host controller is common on all of LPC17xx family. Then you may apply usbh_ohci_lpc17xx.c. The difference is that LPC177x_8x has two USB ports. Depending on the USB port(s) your application assigns, usbh_ohci_lpc17xx.c is modified a little. Which port are you using, port1 (USB_D+1/D-1) or port2 (USB_D+2/D-2), or both?
Tsuneo
> I am using port 1
You may apply usbh_ohci_lpc17xx.c without any change.
In this file, usbh_ohci_hw_init() assigns port1 (U1) to host, port2 (U2) to device, as follows.
usbh_ohci_lpc17xx.c BOOL usbh_ohci_hw_init (BOOL on) { ... LPC_USB->OTGStCtrl |= 0x03; /* Select port function */ // U1 = host, U2 = device
Also, in usbh_ohci_hw_pins_config() in this source file, just the port1 is enabled.
The differences between two drivers are:
/*------------------------- usbh_ohci_hw_delay_ms ------------------------------ * * Delay execution (in milliseconds on 100 MHz CPU clock) * * Parameter: ms: Delay in ms * Return: *----------------------------------------------------------------------------*/ void usbh_ohci_hw_delay_ms (U32 ms) { ms <<= 13; while (ms--) { __nop(); __nop(); __nop(); __nop(); __nop(); __nop(); __nop(); __nop(); __nop(); } } /*------------------------- usbh_ohci_hw_pins_cfg ------------------------------ * * Configurate or unconfigurate pins used by the USB Host. * * Parameter: on: __TRUE = configurate, __FALSE = unconfigurate * Return: __TRUE = Ok, __FALSE = error *----------------------------------------------------------------------------*/ BOOL usbh_ohci_hw_pins_config (BOOL on) { if (on) { /* Set pin functions */ LPC_PINCON->PINSEL1 &= ~((3 << 26) | (3 << 28)); LPC_PINCON->PINSEL1 |= ((1 << 26) |/* P0.29 - USB_D+ (b01) */ (1 << 28));/* P0.30 - USB_D- (b01) */ LPC_PINCON->PINSEL3 &= ~((3 << 4) | (3 << 6) | (3 << 12) | (3 << 22)); LPC_PINCON->PINSEL3 |= ((1 << 4) |/* P1.18 - USB_UP_LED (b01) */ (2 << 6) |/* P1.19 - !USB_PPWR (b10) */ (2 << 12) |/* P1.22 - USB_PWRD (b10) */ (2 << 22));/* P1.27 - !USB_OVRCR (b10) */ } else { /* Reset pin functions */ LPC_PINCON->PINSEL3 &= ~((3 << 4) | (3 << 6) | (3 << 12) | (3 << 22)); LPC_PINCON->PINSEL1 &= ~((3 << 26) | (3 << 28)); } return (__TRUE); } /*------------------------- usbh_ohci_hw_init ---------------------------------- * * Initialize or uninitialize the USB Host Controller. * * Parameter: on: __TRUE = initialize, __FALSE = uninitialize * Return: __TRUE = Ok, __FALSE = error *----------------------------------------------------------------------------*/ BOOL usbh_ohci_hw_init (BOOL on) { S32 tout; if (on) { /* Initialize memory pool for data */ if (!usbh_mem_init(0, (U32 *)&usbh_ohci_mpool, sizeof(usbh_ohci_mpool))) return (__FALSE); LPC_SC->PCONP |= (1UL << 31);/* Enable USB interface power/clock */ LPC_USB->OTGClkCtrl |= 0x19; /* Enable Host, OTG and AHB master clk*/ for (tout = 100; ; tout--) { if ((LPC_USB->OTGClkSt & 0x19) == 0x19) /* Wait for clocks enabled */ break; if (!tout) return (__FALSE); } LPC_USB->OTGStCtrl |= 0x03; /* Select port function */ NVIC_SetPriority (USB_IRQn, 0); /* Set USB interrupt highest priority */ } else { LPC_USB->OTGStCtrl &= ~0x03; /* Deselect port function */ LPC_USB->OTGClkCtrl &= ~0x19; /* Disable Host,OTG and AHB master clk*/ for (tout = 100; ; tout--) { if ((LPC_USB->OTGClkSt & 0x19) == 0)/* Wait for clocks disabled */ break; if (!tout) return (__FALSE); } LPC_SC->PCONP &= ~(1UL << 31);/* Disable USB interface power/clock */ } return (__TRUE); }
/*------------------------- usbh_ohci_hw_delay_ms ------------------------------ * * Delay execution (in milliseconds) * Calibration is done if global variable calDelay is 0 * * Parameter: ms: Number of milliseconds to delay execution for * Return: *----------------------------------------------------------------------------*/ void usbh_ohci_hw_delay_ms (U32 ms) { U32 cnt = 0, vals = 0, vale = 0; start: if (!calDelay) { /* If not calibrated */ cnt = 1000; if (!(SysTick->CTRL & SysTick_CTRL_ENABLE_Msk)) { /* If SysTick timer not running */ vals = 0xFFFFFF; SysTick->LOAD = 0xFFFFFF; SysTick->VAL = 0xFFFFFF; SysTick->CTRL = SysTick_CTRL_CLKSOURCE_Msk | SysTick_CTRL_ENABLE_Msk; } else { vals = SysTick->VAL; /* Timer start value */ } } else { cnt = ms * calDelay; } while (cnt--); if (!calDelay) { /* If not calibrated */ vale = SysTick->VAL; /* Timer end value */ if (vale >= vals) /* If timer reloaded */ vals += SysTick->LOAD; SystemCoreClockUpdate(); /* Update SystemCoreClock variable */ calDelay = SystemCoreClock / (vals - vale); /* Calibrated value */ if (vals == 0xFFFFFF) /* Stop timer if we started it */ SysTick->CTRL = 0; goto start; } } /*------------------------- usbh_ohci_hw_pins_cfg ------------------------------ * * Configurate or unconfigurate pins used by the USB Host. * * Parameter: on: __TRUE = configurate, __FALSE = unconfigurate * Return: __TRUE = Ok, __FALSE = error *----------------------------------------------------------------------------*/ BOOL usbh_ohci_hw_pins_config (BOOL on) { if (on) { /* Set pin functions */ LPC_IOCON->P0_29 = 1; /* USB_D+1 */ LPC_IOCON->P0_30 = 1; /* USB_D-1 */ // LPC_IOCON->P0_31 = 1; /* USB_D+2 */ /* USB_D-2 is dedicated pin */ LPC_IOCON->P1_18 = 1; /* USB_UP_LED1 */ LPC_IOCON->P1_19 = 2; /* !USB_PPWR1 */ LPC_IOCON->P1_22 = 2; /* USB_PWRD1 */ LPC_IOCON->P1_27 = 2; /* !USB_OVRCR1 */ LPC_IOCON->P0_12 = 1 | (1 << 7); /* !USB_PPWR2 */ LPC_IOCON->P0_13 = 1 | (1 << 7); /* USB_UP_LED2 */ LPC_IOCON->P0_14 = 1; /* !USB_HSTEN2 */ LPC_IOCON->P1_30 = 1 | (1 << 7); /* USB_PWRD2 */ LPC_IOCON->P1_31 = 1 | (1 << 7); /* !USB_OVRCR2 */ } else { /* Reset pin functions */ LPC_IOCON->P0_12 = 0xD0; LPC_IOCON->P0_13 = 0xD0; LPC_IOCON->P0_14 = 0x30; LPC_IOCON->P1_30 = 0xD0; LPC_IOCON->P1_31 = 0xD0; LPC_IOCON->P1_18 = 0x30; LPC_IOCON->P1_19 = 0x30; LPC_IOCON->P1_22 = 0x30; LPC_IOCON->P1_27 = 0x30; LPC_IOCON->P0_29 = 0; LPC_IOCON->P0_30 = 0; // LPC_IOCON->P0_31 = 0; } return (__TRUE); } /*------------------------- usbh_ohci_hw_init ---------------------------------- * * Initialize or uninitialize the USB Host Controller. * * Parameter: on: __TRUE = initialize, __FALSE = uninitialize * Return: __TRUE = Ok, __FALSE = error *----------------------------------------------------------------------------*/ BOOL usbh_ohci_hw_init (BOOL on) { S32 tout; if (on) { usbh_ohci_hw_delay_ms (10); /* Calibrate delay */ /* Initialize memory pool for data */ if (!usbh_mem_init(0, (U32 *)&usbh_ohci_mpool, sizeof(usbh_ohci_mpool))) return (__FALSE); LPC_SC->PCONP |= (1UL << 31);/* Enable USB interface power/clock */ LPC_USB->OTGClkCtrl |= 0x19; /* Enable Host, OTG, AHB mster clk */ tout = 10100; while (!((LPC_USB->OTGClkSt & 0x19) == 0x19)) { /* Wait clock enable */ if (tout-- <= 100) { if (tout == 0) return (__FALSE); usbh_ohci_hw_delay_ms (10); /* Wait ~10 ms */ } } LPC_USB -> StCtrl |= 0x03; // 11: U1 = host, U2 = device NVIC_SetPriority (USB_IRQn, 0); /* Set USB interrupt highest priority */ } else { LPC_USB->StCtrl &= ~0x03; /* Deselect port function */ LPC_USB->OTGClkCtrl &= ~0x1F; /* Disable Host,I2C,OTG, AHB mster clk*/ for (tout = 100; ; tout--) { if ((LPC_USB->OTGClkSt & 0x1F) == 0)/* Wait for clocks disabled */ break; if (!tout) return (__FALSE); } LPC_SC->PCONP &= ~(1UL << 31);/* Disable USB interface power/clock */ } return (__TRUE); }
When i call usbh_init(0); return 1-Success, but when i call usbh_hid_status(0,0); return 0 - HID device not connected.Where i am wrong?
The problem was in hardware :) Thank's
