Infineon XMC 1200, RTX_Blinky project, "Cannot access target"
I used the Keil/Arm/Boards/Infineon/XMC1200 Boot Kit/RTX_Blinky project to validate whether my xmc1200 boot kit is ok.
Building it for Flash (XMC1200 Flash) does not give any errors, see here:
*** Note: 'Create Batch File' is active - using 'Rebuild'.
Rebuild target 'XMC1200 Flash'
assembling startup_XMC1200.s...
compiling system_XMC1200.c...
compiling RTX_Conf_CM.c...
compiling LED.c...
compiling Blinky.c...
linking...
Program Size: Code=4120 RO-data=116 RW-data=64 ZI-data=2444
".\Flash\Blinky.axf" - 0 Error(s), 0 Warning(s).
Starting a debug session gives the following error window:
Jlink- Cortex-M error
Shutting down debug session
Doing the build and the debug session for RAM (XMC1200 RAM) works fine, no such JLink error.
Any idea what could be wrong with the XMC1200 Flash project settings?
Thx
