#include<lpc21xx.h> void SendMessage(char *Message); void SendByteSerially(unsigned char a); void initLCD(void); void enable(void); void LCD_WriteChar(unsigned char c); void LCD_WriteString(unsigned char *z); void LCD_Cmd(unsigned int cmd); void delay(void);
#define CR 0x0D
void initLCD(void) { IODIR0 = 0xFF; //P0.0 to P0.7 configured as Output - Using 8 Bit mode IODIR0 |= (1<<16) | (1<<17); //P1.16 and P1.17 configured as Output - Control Pins // IOPIN0 = 0x0; //Reset Port0 to 0. // IOPIN1 = 0x0; //Reset Port1 to 0 - Which also makes RS and Enable LOW.
//LCD Initialization Sequence Now starts delay(); //Initial Delay LCD_Cmd(0x38); LCD_Cmd(0x04); LCD_Cmd(0x01); LCD_Cmd(0x0c); LCD_Cmd(0x80);
// LCD_Cmd(0x3C); //Function Set Command : 8 Bit Mode , 2 Rows , 5x10 Font Style // LCD_Cmd(0x0F); //Display Switch Command : Display on , Cursor on , Blink on // LCD_Cmd(0x06); //Input Set : Increment Mode // LCD_Cmd(0x01); //Screen Clear Command , Cursor at Home // LCD_Cmd(0x80); //Not required the 1st time but needed to reposition the cursor at home after Clearing Screen //Done! }
void enable(void) { delay();
// IOSET1=0x000e0000; IOPIN0 |= (1<<17);//Enable=High delay(); delay(); //IOCLR1=0x000e0000; IOPIN0 &= ~(1<<17);//Enable=Low delay(); }
void LCD_WriteChar(unsigned char c) { IOPIN0 = c& 0x000000FF; IOPIN0 |= (1<<16); //(char)Switch to Data Mode // c+=3; // (char)Supply Character Code enable(); //Pulse Enable to process it !='\0' }
void LCD_WriteString(unsigned char *z) { // unsigned int i=0; while(*z!='\0') { // LCD_WriteChar(*z++);
} /*do {
z++; }while(1); */ }
void LCD_Cmd(unsigned char cmd) { IOPIN0 = cmd& 0x000000FF; IOPIN0 &= ~(1<<17); IOPIN0 &= ~(1<<16); // IOPIN1 = 0x00000000; //Enter Instruction Mode //Supply Instruction/Command Code enable(); //Pulse Enable to process it }
void delay(void) { int i=0,x=0; for(i=0; i<19999; i++){ x++; } } ////////////// int putchar (int ch) { /* Write character to Serial Port */
if (ch == '\n') { while (!(U1LSR & 0x20)); U1THR = CR; /* output CR */ } while (!(U1LSR & 0x20)); return (U1THR = ch); }
int getchar (void) { /* Read character from Serial Port */
while (!(U1LSR & 0x01));
return (U1RBR); }
void srl() { PINSEL0 = 0x00050000; /* Enable RxD1 and TxD1 */ U1LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */ U1DLL = 97; /* 9600 Baud Rate @ 15MHz VPB Clock */ U1LCR = 0x03; } /////////////
void main() { initLCD(); srl(); // 20 INPUT 24 OUT // init_uart1(); IODIR1 &= ~((1<<20)) ; // explicitly making P0.7 as Input - even though by default its already Input IODIR1 |= (1<<21); IODIR1 |= (1<<22);
/* DLAB = 0 */
while(1) { //LCD Now intialized and ready to Print! LCD_Cmd(0x80);LCD_WriteString("RFID BASED VEHICLE"); LCD_Cmd(0xC0); LCD_WriteString("ADHOC N/W");
if( !(IOPIN1 & (1<<20)) ) // Evaluates to True for a 'LOW' on P0.7 { IOSET1 |= (1<<21); // drive P0.30 High
IOCLR1 |= (1<<22); LCD_Cmd(0x01); LCD_Cmd(0x80);LCD_WriteString(" !ALERT!"); LCD_Cmd(0xC0); LCD_WriteString(" ALCOHOL DETECTED");
printf (" ALCOHOL DETECTED\n");
} else if( (IOPIN1 & (1<<20)) ) // Evaluates to True for a 'HIGH' on P0.7 { IOCLR1 |= (1<<21); // drive P0.30 High IOSET1 |= (1<<22); } while ((U1LSR & 0x01)) { if(U1RBR=='a') { LCD_Cmd(0xC0); LCD_WriteString(" 123456"); }}
Is there a question in there somewhere? Also please read the posting tips before pasting in source code in an unreadable form. Thanks
IOCLR1 |= (1<<22); LCD_Cmd(0x01); LCD_Cmd(0x80);LCD_WriteString(" !ALERT!"); LCD_Cmd(0xC0); LCD_WriteString(" ALCOHOL DETECTED IN BLOOD STREAM. LOTS MORE BEER REQUIRED");
printf (" ALCOHOL DETECTED IN BLOOD STREAM - LOTS MORE BEER REQUIRED\n");
} else if( (IOPIN1 & (1<<20)) ) // Evaluates to True for a 'HIGH' on P0.7 { IOCLR1 |= (1<<21); // drive P0.30 High IOSET1 |= (1<<22); } while ((U1LSR & 0x01)) { if(U1RBR=='a') { LCD_Cmd(0xC0); LCD_WriteString(" GLUG GLUG"); }}
That was an even bigger fail than the first post. I guess reading the posting instructions and looking at the preview taxed your concentration too much.
I answered the post! Look. I added some relevance to the mess.
I added some relevance to the mess. a relevant mess is still a mess
the issue here is the OPs imnability to read/follow directions
Whooooooshhhh. The sound made when something said passes straight over your head.
well, that is obvious, you did not not the instructions either
@kevin matusch ....u r a no match dude (being sarcastic) #sic.
define:"erik malund"
Verb, example "to erik malund a post". Entering text into a forum and hitting the post button without first checking for typographical errors, grammar, spelling etc.
that may be, but I follow the posting instructions
