The summary says it all. I am using a project that I last used about 4 months ago and this problem didn't exist. Since then I've moved computers and installed a new copy of uVision. My old computer is NOT available to test it on.
I have made sure TZ is not defined anywhere, that Create Batch File is not checked, and Use Cross-Module Optimization is not checked.
These are the only things I could find on the issue after a good amount of Google and Keil Forum checking. Any other ideas? Thank you!
