I have made code on LPC1317 & tested.
Now on debugging axf file get accessed by keil.
1. Now I want to program large no MCU, will everytime I have to use debugger to write hex file which in tun acces SWDIO/SWCLK lines to program code.
2. but it will also put debug info in MCU also. On debugging, do debug info goes to MCU also or info remain at debugger side only & only code goes to MCU.
3. What if now I directly want to burn hex file for production
You should speak to whoever is going to manufacture your boards - they should have the capability to load code during the manufacturing process.
Also speak to your chip supplier - they should be able to program the chips prior to delivery to the manufacturer (or, at least, be able to recommend 3rd parties to do it).
most major distributors will program the chips for you
