The hardware that I am working on has Relays connected on Port 0 and Port 2 pins of AT89S52 uc. I would like to know if it is possible to initialize the port pins with 0x00 values before the main application starts. I tried doing this:
P0 = P2 = 0xFF; P0 = P2 = 0x00;
but in this case the relay stops to respond. The uc does not communicate after doing this.
Please advice.
I'm curious - how many relays do you have? And how much current do each relay require. Another thing - are there any flywheel diodes connected? You sink the relay current directly with the processor pins? Any other interesting information you have about your design?
24 DPDT relays connected via 74HCT541 and ULN2003A. 10k resistors on Port 0 pins.
And how have you designed the power supply so the supply voltage stays stable and the ground plane doesn't bounce when a larger number of relays gets activated at the same time?
Have you tried to just activate one or two relays at a time?
By the way - why do you want to activate the relays before reaching main()? Because the port pins in reset state have the wrong logic state relative to what you need the relays to do directly on power-on?
The port pins are all high (1) on power on. In this state all the relays are energized. I need them all to be low (0), so that i can switch on the relays that i want.
Maybe replace the 74HCT541 with a 74HCT540?
And how is that different from just switching off all relays you don't want? What's the purpose of switching those that you want on twice, in rapid succession?
Anyway, the above indicates you're trying solve the wrong end of the problem. The problem is with the hardware design, and that means you have to fix your hardware to solve it. It has to change such that port pin low causes the relay to be energized.
If doing the initialization at the beginning of main() is too late, then no change to the software will have any useful effect. The time from the end of reset to the start of main() is just way too short for a relay to notice the difference.
