Dear All,
I use LPC1778 and try to divide internal flash memory for my handmade bootloader and firmware. And when i set another IROM1 start address for my firmware (for example 0x1000) i see SWD Communication Failure message in window "Building Output". After that i can't debug or update my mcu. Can use only ISP. Why changing IROM1 start address is stopping MCU? What i have to do to run my code from any address? P.S. When i use LPC2367 there is no these problems. P.P.S. My version 4.53
I trying apply RAM_MODE, REMAP commands for my startup file. But doesn't work. With best regards, Vladimir.
I sorry, but i'am made big mistake. I use some variables with __attribute__((at(0xxxx))) And durind writing main firmware bootloader was cleared too. Now it's work fine. Thank you veru much for help! Big thanks 'Thorsten Arm' for bootloader code!
Oops!!
That's always a risk with hard-coded absolute addresses!
Thanks for taking the time to give the conclusion.
