Setup heap on external RAM
Hi
I have a board with external RAM and I'm using it quite well, except that I wrote my own malloc and free, which works fine, but I rather use the malloc and free that comes with standard library, I know that wheel will be more reliable than the one I made.
Where is the linker script? I'm using uVision4 IDE and Keil as my compiler.
Basically I want to define heap in a different segment other than the internal RAM of the MCU.
If you can post me an example that will much appreciated.
Alejandro
