TCP Send failing from server application.
Hello all,
I'm having some issues getting my server application to work with TCPnet. I've gotten a few of the examples working with TCP and BSD sockets, but I must be missing something moving forward.
Here is a basic rundown of what I'm trying to accomplish right now:
The TCP Server resides on our embedded device (the cpu is an LPC1788) and waits for a client connection. When the client (a windows forms application on a PC) connects to the server, the server begins periodically sending some measurement data and responding to commands from the client application. Presently, I'm trying to get a proof of concept working where my server simply echo's back the command I sent it, while periodically (about every 100ms) sends a simple two byte message.
My problem is this:
My client attempts to connect and the server accepts the connection.
Upon establishing a connection, I send a command packet from the client.
The server echo's the client command, however, whenever the server attempts to send the "streaming" two byte message, the
send(socket_bsd_con, (char *)&sbuf, 2,0);
command always returns
SCK_EWOULDBLOCK
. I've tried using TCP sockets, BSD sockets, and a number of secnarios (streaming without echoing, echoing without streaming, playing with the timing) and it always seems as though the server side socket can only send a packet if has just received one.
Also, I'm attempting to use non-blocking sockets, and I am not presently using RTX or an RTOS. Rather, I'm using a simpler SysTick interrupt based scheduler.
Here are snippets of the code I'm currently trying to get working:
This is where I initialize the server socket for handling connections:
//initialize the BSD socket and start listening
socket_bsd_server = socket (AF_INET, SOCK_STREAM, 0);
sck_mode=1;//indicates non-blocking mode for the socket
ioctlres = ioctlsocket(socket_bsd_server,FIONBIO,&sck_mode); //pass control parameters
addr.sin_port        = htons(SMC_PORT);
addr.sin_family      = PF_INET;
addr.sin_addr.s_addr = INADDR_ANY;
bres=bind (socket_bsd_server, (SOCKADDR *)&addr, sizeof(addr)); //bind the socket to the addr
lres=listen (socket_bsd_server, 1); //listen for connection requests with a backlog of 1
MsTimerReset(5);//reset one of my "utility" timers
And then after initializing I call this code each 1ms tick in the scheduler:
void TCP_BsdServerTask (void)
  char dbuf[8]; //command buffer
  char sbuf[8]; //the "streaming" data bufer
  uint8_t buf_idx=0;
  if(listen_flag)
     socket_bsd_con = accept (socket_bsd_server, NULL, NULL);
     if(socket_bsd_con>0) //if we got a valid socket handle
       closesocket (socket_bsd_server); //close the server socket to free up resources
       listen_flag=FALSE; //we accepted a connecttion, don't need to listen anymores
     if(socket_bsd_con ==SCK_EWOULDBLOCK)
        //accept doesn't have a connection in queue, we have to try back later
        return;
   }//if listen flag
   res = recv (socket_bsd_con, dbuf, sizeof (dbuf), 0); //try to grab data
   //handle cmd data
   if(res>0) //if there is data available and we're connected
      listen_flag=FALSE;
      if (socket_bsd_con > 0) //if a valid socket handle exists to send with
        send(socket_bsd_con, (uint8_t *)&dbuf, sizeof(dbuf),0);
    if(MsTimerGet(5)>100)//if 100ms has elapsed
       GCB_TIMER_MsTimerReset(5);
             sbuf[0]=0xAA;
             sbuf[1]=0xCC;
             success=send(socket_bsd_con, (char *)&sbuf, 2,0); //<--Problem Here
            /* ^^^^ ALWAYS RETURNS SCK_EWOULDBLOCK ^^^^ */
    }//if Ms timer
}//server task
Sorry if it's a bit messy, I've been trying a bunch of different things to get this to work. Either I'm making some fundamental mistake in how I'm using these sockets, or perhaps I have some issue with the way memory is being allocated for sending date. I can't seem to figure out what I'm doing wrong.
Thanks in advance to anyone that might be able to help me accomplish my goal here.
  • Avoid writing normal text within the "pre" tags. As you can see, you get issues with line length
    breaking the forum formatting. After the formatting has been broken, everyone must manuall add
    line breaks in their posts to make them readable.
    I don't work with the Keil stack, so can't really help with specifics.
    But how have you configured the stack? What amount of memory does it have, so it has room to
    accept multiple outgoing messages even if it is waiting for an acknowledge on an earlier
    transmission? A block doesn't get free for reuse just because it has been sent - the TCP/IP stack
    must support retransmissions so the outging data must be kept until an acknowledge has been
    received.
    Is there any configuration option for handling of acknowledges? A number of TCP/IP stacks have
    issues with acknowledges - nothing wrong but the performance can take a big hit depending on the
    configured behaviour of the stack on the other side.
    received.
