Ethernet no link detection
Dear all
I have build my own custome board using STM32F407IGT6 device and used ST802RT1A as the PHY, when I start debugging and I break at main,my PC recognize the Ethernet link, but when I start the code the link is gone actually when the Ethernet drive code gets to line 300
/* Use autonegotiation about the link speed. */
it will fail to auto negotiate and also when it reach the line 310
/* Check the link status. */
the line status also fails, so the board would not be detected by the PC,
I have used the same schematics form the keil MCBSTM32F400 board, except I have used a 4.99K resistor instead of 5.23K for IREF pin,
Do you have any idea what's going wrong?
