my ocde is not going to main function
hello,
i have opened LPC4357 controller example project from "C:\Keil\ARM\Boards\Keil\MCB4300\Blinky\".
i cofigured it in simulator mode and when i enter into simulation mode my code is not going to main function instead it is pointing to 0x0 memory location where no code is written..even i configured IROM1 as 0x1A000000 with size 0x8000 (i.e onchip Flash memory)and RAM1 0x10000000 and size 0x8000 correctly but i am unable to execute the code..could any one of you please suggest me should i need to change any thing to run it from main function.please try to help me out from this its really very urgent for me
Thanks in advance
Best regards
Cva
  • I haven't read up on your chip, but maybe you need to specifically set PC to the correct start address - if the chip have external pins to decide where to start the boot, then the simulator also have to support them, or you must manually duplicate that functionality by letting a debugger ini file set PC.
