Can you please tell me the step wise process to create the header file . Also tell me where to create this header file, in the notepad or in the keil software itself with in the program. I want to create header file for the following errors: lcd.h rtc.h bcd2ascii.h serial.h For the following program.:-
#include<reg52.h> #include <lcd.h> #include <rtc.h> #include<string.h> #include<bcd2ascii.h> #include<serial.h>
sbit sw1=P3^7; sbit sw2=P3^6; sbit sw3=P3^5; sbit buzzer=P2^3; sbit relay=P2^2; sbit rled =P3^4; sbit gled =P3^3; bit flag_sw,flagr=0;
static unsigned char k=0,s=0x84,*result,h,unit=0; unsigned char inc=23,check_flag=0,month_flag=0,month; unsigned char *time,*res; unsigned char idata byte1[100]; unsigned char *date,*u,i,j,a=0,b,c,d;
void main() { TMOD=0x20; // serial communication intialization TH1=0XFD;SCON=0X50;TR1=1;i=0; IE=0X91;IT0=0;
lcdInit(); // LCD intialization LCDstr("AUTOMATIC POWER",0x80); LCDstr("METER READING",0xc0); delay(2000);
gsm_check();gsm_rec(); //gsm modem intialization gled=0;rled=1;buzzer=1;relay=1;
while(1) //super loop {
//time display LCDstr("DATE ",0x80); LCDstr("TIME",0xc0); date=getDate(); LCDstr(date,0x86); time=getTime(); LCDstr(time,0xc6); flag_sw=0;delay(1000);
//units display putComL(0x01); LCDstr("UNITS=",0x80); putComL(0x86); unit=getCharE(0x15); u=bcdtoascii(unit); LCDstr(u,0x87);
delay(2000);
/**************checking********************/
a=getCharE(0x04); // gsm modem sending sms if(a>=28 ) { gsm_check(); delay(200); ES=0; unit=0; putCharE(unit,0x15); rled=0;gled=1; gsm_send(byte,"number"); }
//else case .. if(a>=16 & d==c){month_flag=1;} else month_flag=0;month_flag=getCharE(0x20);
if(check_flag==0 & month_flag==1 &flagr==0){flagr=1;relay=0;rled=0;gled=1;buzzer=0;delay(100);buzzer=1;} else if(check_flag==1 ){ gled=0;rled=1;buzzer=1;relay=1;} delay(1000);
//receving sms for(j=0;j<100;j++) {if(byte1[j]=='*' &byte1[j+1]=='P' & byte1[j+2]=='A'& byte1[j+3]=='I'& byte1[j+4]=='D') {ES=0;LCDstr("received",0xc0); a=1;check_flag=1;putCharE(check_flag,0x10); gsm_rec(); }} //time setting
if(sw3==0){enter_time();} delay(1000);k=0;
Please also tell me whether the program is correct or not.. please Guide me
