Hello Sir,
I am working on USB host using LPC2468. I am facing a problem when i try to create 6 different file it creates 5 files on pendrive 6th file is not creating my code is like that
for(file_no =1;file_no<=6;file_no++) files_on_pendrive(); void files_on_pendrive(void){ switch(file_no){ case 1: cashier_dbase(); break; case 2: tax_dbase(); break; case 3: billsumm_dbase(); break; case 4: crd_trans_dbase(); break; case 5: bill_copy_dbase(); break; case 6: pagewise_dbase(); break; } }
in the above code each switch case creates a file but case6 is not creating the file if i place case 5 function in place of case6 function then again case6 is not creating a file what,s the reason behind it.
