Automatic RESET during operation
i am facing a wierd problem.. My MCU P89V51RD2BN resets during Execution...
i am a college student and a beginner Here so i dont know the Advanced Programming methods
i would also inform that..
i have a recursive function , a warning is issued by the compiler for the same. but....
earlier this was not a problem but since i have modified some of the Sub-Routines for 16Bit Data this Problem has come up, i need those functions to be 16 bit because of the limitation of the ALU i was earlier using 8bit and leaving most of the Task to Assumption which i cannot do so now..
i would also state that the Problem occurs in a fumction at a point when i call 2 functions in the same code, these themselves call around 5 sub-routines each but that wasnt a problem earlier (before i used the 16bit return type sub-routines).
now i found something in the manual stating reentrant Functions, but i really dont know how to use it
i used it like this
void Home_Screen_Instance() reentrant
} Do i need to use the keyword "reentrant" in the Function Decleration too?
but that didnt help either
but the compilers shows an error Home_Screen_Instance : redefinition.
Target Not Created
this was the first of a kind problem that i encountered, my MCU is resetting itself for sure(i checked that with a dummy subroutine of blinking LED) and it is not because of the watchdog timer, i am sure about that too..
so whats the Problem here?
is the Stack overflowing???
or there is any other reason behind this?
should i revert back to the 8bit versions of my subroutine (without any other choice)?
is it because of the recursive nature of the function H0me_screen_instance?
Related Data:
The Program is Display intensive, i mean there are a lot of Strings to be displayed and they are stored beforehand in XDATA,
message shown during sucessfull compilation, (still resets)
Program Size: data 9.4 xdata 252 code 9514
creating hex-----blah blah blah----
0 Error(s) 65 Warning(s)
