I am trying to use the following code to convert 2 digit ASCII numbers to BCD number, for setting RTC Clock DS1307.
unsigned char ASCII_TO_BCD(unsigned char ascii_text[2]) { unsigned char bcd_value; ascii_text[0] &= 0x0F; // set high nibble(3) to 0 (may not be needed) ascii_text[0] <<= 4; // shift lower nibble to higher ascii_text[1] &= 0x0F; // set high nibble(3) to 0 (may not be needed) bcd_value = ascii_text[0] | ascii_text[1]; // mix both to get BCD return bcd_value; }
When I pass '12' to the function, 0x33 is returned instead of 0x12. Is something wrong in this code? Thanks.
