Welcome,
Does anybody know where µVision4 saves it's configuration? I know about "global.prop" but there are no "Shortcut-keys".
Run regedit and search for keil:
HKEY_CURRENT_USER\Software\Keil\µVision4
I suspect that is what you are looking for.
No. It's not that.
When you delete whole key, some of settings (like short-cuts) still remains.
Which sort of short cuts? for example?
HKEY_CLASSES_ROOT\UV2FILE\Shell\open\command\"C:\Keil\UV4\UV4.EXE" "%1" HKEY_CLASSES_ROOT\UVPROJFILE\Shell\open\command\"C:\Keil\UV4\UV4.EXE" "%1"
All in IDE (uV4): Edit->Configuration Tab "Shortcut Keys". I have deleted registry key and "global.prop" file but those settings are still on place.
Look deepper into register, I think is there, this one seems to control buttons configurations. No harm in KEIL deleting the registry if you need.
HKEY_CURRENT_USER\Software\Keil\µVision4\DefaultDebug\MFCToolBar-183\ "some user button values are set here"
I've checked whole key in registry. Unfortunately it's not that.
I know: uV4.mac in Keil\uV4 directory. There are IDE shortcuts!
