Hi I'm doing this project about Monitor and Control Green House Effect, I got no Error neither a warning but i cant build a Target due to memory is exceeding the limit. Here is My code and build output. Im using Microcontroller "Atmel AT98S52" with interaction of analogy to digital Converter ADC0808
"Build target 'Target 1' linking... BL51 BANKED LINKER/LOCATER V6.22 - SN: Eval Version COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2009 "STARTUP.obj", "Green house.obj" TO "Green house" RAMSIZE(256) ****************************************************************************** * RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 0953H BYTE (116%) * ****************************************************************************** Program Size: data=93.1 xdata=0 code=3640 LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 0 ERROR(S) *** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED MODULE: C:\KEIL\C51\LIB\C51S.LIB (-----) LIMIT: 0800H BYTES Target not created"
Please help me i need to finish this in less than a mouth.
What help do you want? Someone to buy a commercial license of the tools and donates to you?
What does your teacher say about your code exceeding the size allowed by the evaluation version of the tools? Or is there something wrong with the installation, so the tools should actually have a valid license file?
I dont know how to get a full version of tools ie C51. Can u tell me plz
Yes coz i'm writing a prog for 8051 family, Mc "AT89S52"
R U kidding me? Do you think there's no 51 compiler except Keil?
And you don't know how to buy something?
It has nothing to do with the compiler! The chip is the limiting factor.
People with the world's biggest supercomputers can't control the planet's climate!!
Its not about world's climate, my project is about monitoring and control inhouse green house effect and its for inside green house. anyway i will find another way. Thanks for your concern..
That link seemed to point to the C251 tools and not the C51 tools.
Ofcourse i notice but i tried to reinstall my software and its license files and they works fine, my target files are compiled well and i got my output.. Thanks all of you guys, you are real Helping.
