Memory Exceed
Hi I'm doing this project about Monitor and Control Green House Effect, I got no Error neither a warning but i cant build a Target due to memory is exceeding the limit. Here is My code and build output. Im using Microcontroller "Atmel AT98S52" with interaction of analogy to digital Converter ADC0808
"Build target 'Target 1'
linking...
BL51 BANKED LINKER/LOCATER V6.22 - SN: Eval Version
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2009
"STARTUP.obj",
"Green house.obj"
TO "Green house"
RAMSIZE(256)
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 0953H BYTE (116%) *
Program Size: data=93.1 xdata=0 code=3640
LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 0 ERROR(S)
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED MODULE: C:\KEIL\C51\LIB\C51S.LIB (-----) LIMIT: 0800H BYTES
Target not created"
Please help me i need to finish this in less than a mouth.
  • What help do you want? Someone to buy a commercial license of the tools and donates to you?
    What does your teacher say about your code exceeding the size allowed by the evaluation version of the tools? Or is there something wrong with the installation, so the tools should actually have a valid license file?
