Hello All, I just started to lean the basics of ARM. I tried with the following program with LPC2148 and it works perfectly.
/********************************************************* #include <LPC214x.H> void delay(void);
int main(void) { IODIR0=0xFFFFFFFF;
while(1) {
IOSET0|=0xFFFFFFFF; delay(); IOCLR0=0xFFFFFFFF; delay(); delay();
void delay(void) { int z,c; c=0; for(z=0; z<4000000; z++) { c++; } }
IOSET0=0xFFFFFFFF; delay(); IOCLR0=0xFFFFFFFF; delay();
But I do have a problem with it. When I try to turn ON/OFF a single PIN for ex: P0.3 using the following statements, it never works. Please help me to get solved. What should I do more to make it work?
IODIR0|=(1<<3);
IOSET0|=(1<<3); delay(); IOCLR0|=(1<<3); delay();
Hello Is there any alternate instead of using HLL Loop ?
The program works in Proteus. But in real hardware, it fails.
Do you think that maybe Google can find alternatives to software-only busy loops?
You didn't bother following the links, then.
