enum external declaration and use
Hi Folks,
I am trying to use enum to define a set of named constants with values so that they can be used by multiple C files in my project. For example. I use the following snipet to define Months in a headers file externals.h, and then If I then try to use it as follows in any of those files, it does not work.
 enum MONTHS {M1 = 'Jan', M2 = 'Feb', M3 = 'Mar'};
extern enum MONTHS; // should it be extern enum MONTHS months; ?
SendByte (M1);//(This routine display M1 on my serial port).
I get error ---> (...error 230 MONTH unknown struct/union/enum tag)
What is the problem and how can I fix it ?
I would like to get a better understanding of this enum business, if possible..
Thanks.
Bhal Tulpule
  • An enum is a data type, not a variable. The compiler needs to know the definition of the enum before you can use it, or you'll get an "unknown struct/union/enum" error.
    You need to define the full enum in a header file.
    It still won't work, though, in your case because enums must be numeric -- you can't use a char array.
