hi all
I've worked with tcp library with 4.2 version without any problem
now i switched to 4.7 version
when i program my code it works properly (answer my ping)
but when i turn it off and on (reset) it doesn't answer my ping !
thank
"when i program my code it works properly (answer my ping)"
What, exactly, do you mean by, "program my code"?
Do you mean downloading it via JTAG, and then starting it with the debugger?
"but when i turn it off and on (reset) it doesn't answer my ping !"
So there's something wrong with the Reset in your system!
When you download and/or start your code via JTAG, the JTAG resets the processor; when you just turn off & on, it's all down to your system to apply proper reset conditions...
yes i download via jtag , no i don't debug .
if u mean my hardware my hardware is OK I've already tested it with other code .
but if u mean software it's a simple code that i use from keil sample .
as i knew it's startup file job
Thank
