UVSOCK improvements
I am currently implementing Tcl bindings to the UVSOCK library. This will allow UV to be scripted in Tcl. (German note to Keil personell: Ich war auf Ihrem Stand auf der Embedded World und hatte z.B. einige Vorschlaege fuer CMSIS. Vielleicht erinnern Sie sich.)
I've noticed some things that could stand improvement in the UVSOCK documentation.
UVSC_Init() fails with General Failure if passed UVSC_MIN_AUTO_PORT and UVSC_MAX_AUTO_PORT. It succeeds if passed the values 5101 and 5110, as in the UVSC_Tester application. You may want to document this; it took me some time to figure this out.
The REGENUM struct is not documented in the HTML, only in the source file; this is probably because of incorrect Doxygen comments.
Sincerly,
Konrad Schwarz
  • Despite documentation to the contrary (*), UVSC_OpenConnection()'s uvRunmode parameter is not ignored when uVision is not being auto-started. It seems it is range checked in any case. An out of range value for uvRunmode results in a General Failure error.
    (*) quoting from the manual:
    uvRunmode Indicates the mode uVision should be started in when auto-started. If uVision is not being auto-started this parameter is ignored
    You might want to add "... this parameter is ignored, except that it is range checked".
