I am testing RTX task and I always get hard_fault when I use FPU and float. Please help, what am I missing?
This is my code:
#include <RTL.h> #include "stm32f4_discovery.h" #include "stm32f4xx_i2c.h" #include "stm32f4xx_gpio.h" #include "stm32f4xx_rcc.h" #include "stm32f4xx_tim.h" #include "misc.h" #include "LED.h" #include "ssd1308.h" #include <stdio.h> __align(8) static U64 stk1[100]; void testOne( float b ) { float a = 1.2f; char buffer[16]; sprintf( buffer, "%f", a+b ); SSD1308_setTextXY( 0, 0 ); SSD1308_putString( buffer ); } __task void task1 (void) { int a = 0; char buffer[8]; float b = 0.001f; for (;;) { LED_On (LED_A); b += 0.001f; testOne( b ); a++; if( a > 128*64 ) a = 0; LED_Off(LED_A); } } /*---------------------------------------------------------------------------- * Main: Initialize and start RTX Kernel *---------------------------------------------------------------------------*/ int main (void) { char buffer[16]; LED_init (); /* Initialize the LEDs */ SSD1308_Init(); SSD1308_clearDisplay(); SSD1308_Send( SSD1308_Command_Mode, SSD1308_Dectivate_Scroll_Cmd ); os_sys_init_user (task1, 10, &stk1, sizeof(stk1)); /* Initialize RTX and start init */ while(1); } /*---------------------------------------------------------------------------- * end of file *---------------------------------------------------------------------------*/ #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t* file, uint32_t line) { /* User can add his own implementation to report the file name and line number, ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */ /* Infinite loop */ while (1) { } } #endif /** * @} */ /** * @} */ /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
regards.
Make sure SystemInit() in system_stm32f4xx.c is being called, and the correct defines cause the FPU to be enabled.
void SystemInit(void) { /* FPU settings ------------------------------------------------------------*/ #if (__FPU_PRESENT == 1) && (__FPU_USED == 1) SCB->CPACR |= ((3UL << 10*2)|(3UL << 11*2)); /* set CP10 and CP11 Full Access */ #endif
That's it! thank you so much! How come I didn't find that information anywhere else? What document/manual should I look up for?
Best regards.
