Problem erasing sectors ( IAP_EraseSec )
I need help. I'm using the IAP, secondary bootloader.
I'm having a problem erasing sectors.
When I try to erase a sector, it hangs at function "iap_entry(command, result)" in erase function.
It passes through Prepare function successfully.
The code:
#define IAP_LOCATION   0x7FFFFFF1
#define IAP_CLK        48000000
#define AP_ADDR        0x10000// where the user app located
typedef void (*FP)(void);/* run the user application from pre-specified address*/
#define iap_entry(a, b)     ((void (*)())(IAP_LOCATION))(a, b)
unsigned long  command[5];
unsigned long  result[3];
The ERASE FUNCTION:
unsigned long IAP_EraseSec (unsigned long StartSecNum,  unsigned long EndSecNum)
        if (EndSecNum < StartSecNum)
                return IAP_STA_INVALD_PARAM;
        command[0] = IAP_CMD_EraseSec;
        command[1] = StartSecNum;
        command[2] = EndSecNum;
        command[3] = IAP_CLK / 1000;
        _printf("\r\n*******ERASE3************");
        iap_entry(command, result);
        _printf("\r\n*******ERASE4************");
        return result[0];
The PREPARE FUNCTION:(that one works ok)
unsigned long IAP_PrepareSec (unsigned long StartSecNum, unsigned long EndSecNum)
        return result[0];
Can anyone help me?
thanks
