#include<stdio.h>
int main() { unsigned char buff; FILE *fp = fopen("Hi.txt","r"); FILE *out = fopen("Hi1.txt","w"); while(!feof(fp)) { fread(&buff,1,1,fp); fprintf(out, "%d ,",buff); } fclose(fp); fclose(out); return 0; }
This code i am able to run on MingGW. But on Keil i am able to compile only but not able to Debug Why?
For your unspecified board/chip, you'd need to be implementing a file system, and IO routines for your mass storage device.
This is embedded, their is no OS functionality beyond that which you implement yourself.
Thanks for reply,
My aim is to store one file into EEPROM.
I am using JTAG.
Can i do like that i read file from system harddisk and store it in EEPROM. This thing i want to do while debugging by uLINK2.
My file is to long i can not do that i put whole file into RAM or Flash.
Consider creating a Flash Algorithm applet, see \Keil\ARM\Flash for other examples. Then commands like "LOAD" should work in the debugger.
Other alternatives are to implement X/Y-Modem and drivers for your memory, and download files to the target from your terminal app.
