I write two codes for generating greq at PA0-Pa7: Diff in code 1 & code 2 is that only BSSR register is moved to define macro.
code1
#define WRITE_TFT_DATA_PINS(VALUE) { \ GPIOA->BSRRL = (uint16_t)( VALUE & 0x000000ff); \ GPIOA->BSRRH = (uint16_t)(~VALUE & 0x000000ff); \ } void main() { for( i = 8; i < 255; i++ ) { WRITE_TFT_DATA_PINS(i); } }
code2
void main() { for( i = 8; i < 255; i++ ) { GPIOA->BSRRL = (uint16_t)( VALUE & 0x000000ff); GPIOA->BSRRH = (uint16_t)(~VALUE & 0x000000ff); } }
Now on checking freq on PA7 pin for code 1 = 55Khz & for code 2 = 65Khz (approx.)
I checked the preprocessor file of both code, both are almost same code1
while(1) { uint32_t i; for( i = 8; i < 255; i++ ) { { ((GPIO_TypeDef *) ((((uint32_t)0x40000000) + 0x00020000) + 0x0000))->BSRRL = (uint16_t)( i & 0x000000ff); (GPIO_TypeDef *) ((((uint32_t)0x40000000) + 0x00020000) + 0x0000))->BSRRH = (uint16_t)(~i & 0x000000ff); }; } }
while(1) { uint32_t i; for( i = 8; i < 255; i++ ) { ((GPIO_TypeDef *) ((((uint32_t)0x40000000) + 0x00020000) + 0x0000))->BSRRL = (uint16_t)( i & 0x000000ff); ((GPIO_TypeDef *) ((((uint32_t)0x40000000) + 0x00020000) + 0x0000))->BSRRH = (uint16_t)(~i & 0x000000ff); } }
Then i checked its disassembly , after for loop:
0x0800020E 2008 MOVS r0,#0x08 0x08000210 B2C2 UXTB r2,r0 0x08000212 830A STRH r2,[r1,#0x18] 0x08000214 43C2 MVNS r2,r0 0x08000216 B2D2 UXTB r2,r2 0x08000218 834A STRH r2,[r1,#0x1A] 0x0800021A 1C40 ADDS r0,r0,#1 0x0800021C 28FF CMP r0,#0xFF 0x0800021E D3F7 BCC 0x08000210 0x08000220 E7F5 B 0x0800020E
0x0800021A 2109 MOVS r1,#0x09 0x0800021C B2CA UXTB r2,r1 0x0800021E 8302 STRH r2,[r0,#0x18] 0x08000220 43CA MVNS r2,r1 0x08000222 B2D2 UXTB r2,r2 0x08000224 8342 STRH r2,[r0,#0x1A] 0x08000226 1C4A ADDS r2,r1,#1 0x08000228 B2D4 UXTB r4,r2 0x0800022A 8304 STRH r4,[r0,#0x18] 0x0800022C 43D2 MVNS r2,r2 0x0800022E B2D2 UXTB r2,r2 0x08000230 8342 STRH r2,[r0,#0x1A] 0x08000232 1C89 ADDS r1,r1,#2 0x08000234 29FF CMP r1,#0xFF 0x08000236 D3F1 BCC 0x0800021C 0x08000238 E7EC B 0x08000214
My question is when both coeds are same except define which I don't think should change the code assembly. Also optimzation and other parameter are same for both
It's curious. It seems that the empty statement formed by using the the macro is preventing loop unrolling (for no good reason).
Try changing your macro to
#define WRITE_TFT_DATA_PINS(VALUE) do { ... } while (0)
instead of
#define WRITE_TFT_DATA_PINS(VALUE) { ... }
Using do/while(0) is a common thing to do with multi-statement macros and will save you some confusion if you ever use any constructs that won't accept an empty statement like:
... if (b) WRITE_TFT_DATA_PINS(i); else bar(); ...
