interrupt number in STR9_ENET.c
In the following driver code (In Keil MDK4: .../Keil/ARM/RL/TCPNet/Drivers/STR9_ENET.c), It says that "Configure VIC for EMAC interrupt" and it uses "14" as index of VIC->VAiR[14] for EMAC, however In datasheet of STR912FAxx www.st.com/.../CD00159308.pdf it says VIC0.11 Ethernet MAC
Logic OR of Ethernet MAC interrupts via its own dedicated DMA channel
on page 19.
STR9_ENET.c file is suitable for STR912FAW44(on Keil's MCBSTR9) devices?
  VIC0->DVAR     = (U32)def_interrupt;
  VIC0->VAiR[14] = (U32)interrupt_ethernet;
  VIC0->INTSR   &= ~(1 << 11);
  VIC0->VCiR[14] = 0x20 | 11;
 *      RL-ARM - TCPnet
 *      Name:    STR9_ENET.C
 *      Purpose: Driver for ST STR912 ENET Ethernet Controller
 *      Rev.:    V4.20
 *      This code is part of the RealView Run-Time Library.
 *      Copyright (c) 2004-2011 KEIL - An ARM Company. All rights reserved.
#include <Net_Config.h>
#include "STR9_ENET.h"
#include <91x_lib.h>                    /* STR912F definitions               */
void init_ethernet (void) {
  /* Initialize the ENET ethernet controller. */
  U32 regv,tout,id1,id2;
  /* Reset ENET and DMA devices. */
  ENET_DMA->SCR |= SCR_SRESET;
  /* Enable GPIO1 Ethernet Pins. */
  GPIO1->DDR         |=  0x9E;
  GPIO1->DR[0x9E<<2]  =  0x00;
  SCU->GPIOTYPE[1]   &= ~0x9E;
  SCU->GPIOIN[1]     &= ~0x9E;
  SCU->GPIOOUT[1]    &= ~0xC3FC;
  SCU->GPIOOUT[1]    |=  0x82A8;
  /* Enable GPIO5 Ethernet Pins, drive MII clock 25MHz. */
  GPIO5->DDR         |=  0x0C;
  GPIO5->DR[0x0C<<2]  =  0x00;
  SCU->GPIOTYPE[5]   &= ~0x0C;
  SCU->GPIOIN[5]     &= ~0x0C;
  SCU->GPIOOUT[5]    &= ~0x00F0;
  SCU->GPIOOUT[5]    |=  0x00A0;
  /* Remove reset for ENET and MAC devices */
  ENET_DMA->SCR &= ~SCR_SRESET;
  /* Initialize MAC control register, accept multicast packets. */
  ENET_MAC->MCR = MCR_PFM_MCAST | MCR_RVFF | MCR_APR | MCR_DCE;
  /* If HCLK > 50MHz enable the following line. */
  //ENET_MAC->MCR |= MCR_PS_DEF;
  /* Setup Tx & Rx burst size. */
  regv = ENET_DMA->SCR & ~(SCR_TX_BURST_SIZE | SCR_RX_BURST_SIZE);
  ENET_DMA->SCR = regv |  (SCR_TX_BURST_DEF  | SCR_RX_BURST_DEF);
  /* Set clock to PCLK */
  ENET_DMA->CCR = (ENET_DMA->CCR & CCR_SEL_CLK) | CCR_SEL_CLK_DEF;
  /* Put the STE100P in reset mode */
  write_PHY (PHY_REG_XCR, 0x8000);
  /* Wait for hardware reset to end. */
  for (tout = 0; tout < 0x100000; tout++) {
    regv = read_PHY (PHY_REG_XCR);
    if (!(regv & 0x8000)) {
      /* Reset complete */
      break;
  /* Check if this is a STE100P PHY. */
  id1 = read_PHY (PHY_REG_PID1);
  id2 = read_PHY (PHY_REG_PID2);
  if (((id1 << 16) | (id2 & 0xFFF0)) == STE100P_ID) {
    /* Configure the PHY device */
#if defined (_10MBIT_)
    /* Connect at 10MBit */
    write_PHY (PHY_REG_XCR, PHY_FULLD_10M);
#elif defined (_100MBIT_)
    /* Connect at 100MBit */
    write_PHY (PHY_REG_XCR, PHY_FULLD_100M);
#else
    /* Use autonegotiation about the link speed. */
    write_PHY (PHY_REG_XCR, PHY_AUTO_NEG);
    /* Wait to complete Auto_Negotiation. */
      regv = read_PHY (PHY_REG_XSR);
      if (regv & 0x0020) {
        /* ANEG_ACK set, autonegotiation finished. */
        break;
#endif
  /* Check the link status. */
  for (tout = 0; tout < 0x10000; tout++) {
    if (regv & 0x0004) {
      /* Link is on. */
      break;
  regv = read_PHY (PHY_REG_XCIIS);
  if (regv & 0x0100) {
    /* Full duplex is enabled. */
    ENET_MAC->MCR |= MCR_FDM;
  else {
    /* Half duplex mode. */
    ENET_MAC->MCR |= MCR_DRO;
  /* Set the Ethernet MAC Address registers */
  ENET_MAC->MAH = ((U32)own_hw_adr[5] << 8)  |  (U32)own_hw_adr[4];
  ENET_MAC->MAL = ((U32)own_hw_adr[3] << 24) | ((U32)own_hw_adr[2] << 16) |
                  ((U32)own_hw_adr[1] << 8)  |  (U32)own_hw_adr[0];
  /* Initialize Tx and Rx DMA Descriptors */
  rx_descr_init ();
  tx_descr_init ();
  /* Force a ENET abort by software */
  ENET_DMA->RXSTR |= RXSTR_DMA_EN;
  ENET_DMA->TXSTR |= TXSTR_DMA_EN;
  /* Setup Descriptor Fetch Delay */
  ENET_DMA->RXSTR = (ENET_DMA->RXSTR & ~RXSTR_DFETCH_DLY) | RXSTR_DFETCH_DEF |
                     RXSTR_COLL_SEEN |  RXSTR_RUNT_FRAME  | RXSTR_FILTER_FAIL;
  ENET_DMA->TXSTR = (ENET_DMA->TXSTR & ~TXSTR_DFETCH_DLY) | TXSTR_DFETCH_DEF |
                     TXSTR_UNDER_RUN;
  /* Enable ENET interrupts. */
  ENET_DMA->IER   = INT_RX_CURR_DONE | INT_TX_CURR_DONE | INT_RX_DONE;
  /* Reset all interrupts */
  ENET_DMA->ISR   = 0xFFFFFFFF;
  /* Enable receive and transmit mode of MAC Ethernet core */
  ENET_MAC->MCR  |= (MCR_TE | MCR_RE);
  /* Start the receive operation */
  ENET_DMA->RXSTR |= RXSTR_START_FETCH;
  /* Configure VIC for EMAC interrupt. */
