Hi, please look into this code Code: #include "REG52.h" #include "intrins.h"
void main() { long int data1 = 0xFF000000; char shift = 0xA0; data1 = _lrol_(data1,8); data1 = data1 & 0xFFFFFF00; data1 = data1 + shift; }
the value of data1 i expect is 0x000000A0, but when i execute the above code, it shows a value of data1 = 0xFFFFFFA0. I am not understanding why it should add 0xFFFFFF in its previous byte.
I am using Keil IDE-Version: µVision3 V3.60 and C Compiler: C51.Exe V8.12
Can anyone tell me, if something is wrong ?
regards, Kume
That code has a good deal more problems than the one you saw with "addtion"(sic).
* 0xFF000000 doesn't fit into a long int * 0xA0 may not fit into a char (depending on compiler settings) * _lrol_() is supposed to used with unsignedlong int * _lrol_() returns a value of a type different from that of data1 * 0xFFFFFF00 doesn't fit into a long int
Given all thos einfractions, any expectation formed about the result of that program is bound to be wrong.
Based on your point, I think i got the solution to my problem
#include "REG52.h" #include "intrins.h" typedef char int8; void main() { unsigned long data1 = 0xFF000000; unsigned char shift = 0xA0; data1 = _lrol_(data1,8); data1 = data1 & 0xFFFFFF00; data1 = data1 + shift; }
Thank you for enlightening me about unsigned... i forgot about it though :-P
But, if i go back and see the mistake i did.. without keyword 'unsigned' it was considering as signed long and singed char [if i am right], but is it natural for any compiler to add FF when it is typecasting to long int ?? why should it do ?? can you please explain ?
When a signed number is converted to more bits, the value is sign-extended. I.e. if most significant bit is set, it tells that the number is negative. When storing in a larger format, then all the extra bits must also be one to still represent the same negative value.
0xa0 have the most significant bit set. So if stored in a signed byte, it doesn't represent the value 160. And if moved to a 16-bit signed integer, the value stored will be 0xffa0. If stored in a 32-bit integer, the value stored will be 0xffffffa0.
So signed or unsigned is really very important.
Another thing. You continue to use long constants without considering using the ul suffix. Why?
