SPI is not working on LPC2294 board
Hi All,
the SPI code is working fine with keil simulator and it is going to ISR whenever SPIF is set.
but when the same code is loaded to LPC 2294 hardware board it is not working
and indefinitely waiting for SPIF bit.
In the above case, whenever data is written to S0SPDR interrupt is getting generated (observed on Vector Interrupt Controller) but it is not entering in to ISR and waiting continuously for SPIF.
no activity is detected on the SPI port pins(on logic analyzer )
other interrupts are working fine(timer is checked) but I am understanding why SPI is not working
the code is for interfacing the SPI flash(S70fl256)with LPC2294 MCU and the code is as follows
#define NULL    ((void *)0)
#define False   (0)
#define True    (1)
#define SPIF            1 << 7
#define INTERRUPT_MODE  1
typedef unsigned char  BYTE;
typedef unsigned short WORD;
typedef unsigned long  DWORD;
typedef unsigned int   Bool;
#include <LPC22xx.H>
#include "spi.h"          //all prototypes and variables def
void Wait(unsigned long cnt)
        while(--cnt);
void Flash_MemWrite(unsigned char *buf,unsigned char *SPI0Add,unsigned char Length)
        unsigned char i,Dummy;
        IOCLR1= 0x00010000;             /* to generate #CS1 of SPI flash*/
        Wait(5);
        S0SPDR = 0x06;             /* to set write enable latch */
        while ( !(S0SPSR & SPIF) );
        Dummy = S0SPDR;         /* Flush the RxFIFO */
        IOSET1= 0x00050000;     /* to disable  #CS1 and to pull up #Hold of SPI flash */
        Wait(5);
        S0SPDR = 0x02;            /*Page Program (PP) command enables memory array data to be programmed*/
/* before sending data 3 bytes of address has to be sent*/
  for ( i = 0; i < 3; i++ )
        S0SPDR = *SPI0Add;
        SPI0Add++;
/* now send the data */
  if ( Length == 0 )
        {       return; }
  for ( i = 0; i < Length; i++ )
        S0SPDR = *buf;
        Dummy = S0SPDR;         // Flush the RxFIFO
        buf++;
        Wait(0xF);
        IOSET1= 0x00050000;     // to disable  #CS1 and to pull up #Hold of SPI flash
unsigned char *Flash_MemRead(unsigned char *SPI0Add, unsigned char Length)
        unsigned char temp[256],Dummy,i;
        Wait(5);
        S0SPDR = 0x03;             /* read command */
        /* before reading data 3 bytes of address has to be sent*/
        for (i = 0; i < 3; i++ )
        S0SPDR = *SPI0Add;
        SPI0Add++;
/* now receive the data */
        S0SPDR = 0xFF;
        temp[i]=S0SPDR;
        return  temp;
void DefinePins(void)
        PINSEL0 = 0x2000155C;
        PINSEL1 = 0x000002A8;
        IOSET1  = 0x00050000;   // to disable  #CS1 and to pull up #Hold /*of SPI flash */
        IODIR1 = 0x00050000;
void SPI0Handler (void) __irq
  S0SPINT = 0X01;               /* clear interrupt flag */
  VICVectAddr = 0;              /* Acknowledge Interrupt */
void Spi_Init()
        PCONP=0X0D86;   /* to enable I2C and SPI ports */
        S0SPCR = 0x00A8;        //SPI0-active high, master,int enabled,8 bit format and clk //phase is 1
        S0SPCCR = 0x0A;
#if INTERRUPT_MODE
  VICIntEnClr =0xFFFFFFFF;      /* Disable Interrupts */
  VICVectAddr3 = (unsigned long)SPI0Handler;    /* set interrupt vector */
  VICVectCntl3 = 0x00000020 | 10;
  VICIntEnable |= 0x00000400;    // 10 th bit   to enable SPI0
  S0SPCR = 0x00A8;      //8 bits per transfer,interrupt enable, master     //for SPI flash
#endif
        return;
Bool Flash_Test(void)
        Bool Mem_flag= True;
        unsigned char *temp,SPI0Data[256],SPI0Add[3];
        unsigned char i;
        SPI0Add[0]=0x1;//10;
        SPI0Add[1]=0x2;//0;
        SPI0Add[2]=0x3;//0;
        for (i=0 ;i < 2; i++)
                SPI0Data[i] =0x0AA;
        Flash_MemWrite(SPI0Data,SPI0Add,2);
        temp = Flash_MemRead(SPI0Add,2);
        if(temp[i]!= 0x0AA)
                        Mem_flag = False;
                        break;
        if(Mem_flag)
                return True;
        else
                return False;
int main(void)
        Bool flash_flag;
        DefinePins(); /* Define Pinsel0,1;*/
        Spi_Init();
        flash_flag=Flash_Test();
        while(1);
please help me and let me know where I am missing.
Thank you in advance
  • Hi all,
    it is entering into ISR when I put a break point inside the ISR but it is not pushing any data on the SPI port pins.
    it is not entering into ISR when I do step wise execution. the reason for this may be the time it is spending in ISR is lesser than the time required between the two step wise executions.
    can anyone tell me why it is not pushing data on to the SPI port.
    Thank you in advance,
  • Hi all,
