Hi...!! I have one problem related to keil setting. This is my code given below. which is working fine. which below keil setting.
keil > go in "flash" option > "config flash tool" > "Target" > tick "IROM1" (for start =0x0 to size =0x80000)
but when I do change in "IROM" (start = 0x2000 to size = 0x80000), At the time of interrupt, program is not generate any vector address table at 0x18,so I can't able to jump in to IRQ routine.
IS THIS ANY SETTING HAS TO BE DONE WHEN I WRITE 2000 IN IROM ??
#include <LPC214x.H> /* LPC21xx definitions */ #include "Serial.h" #define CR 0x0D extern char ch; void uart0_getkey (void) __irq // This is the func which contr need to call when an interrupt occurs { VICVectAddr=0x00; b=1; ch = U0RBR; } //---------------------------------------------------------------------------// //------------------- Function for Initial UART0 ----------------------------// //---------------------------------------------------------------------------// void uart0_init() { /* initialize the serial interface */ PINSEL0 = 0x00000005; /* Enable RxD0 and TxD0 */ U0LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */ U0DLL = 0xc2; /* 9600 Baud Rate @ 30MHz VPB Clock */ U0LCR = 0x03; /* DLAB = 0 */ VICIntSelect= 0x00; VICVectCntl0 = 0x20 | 6; VICVectAddr0 = (unsigned long)uart0_getkey; U0IER = 0x01; // enabled Receive interrupt VICIntEnable = 0x0040; temp = U0RBR; } //------------------------------------------------------------------------------------------------// //---------------------------- Function for send character 1 time via UART0-----------------------// //------------------------------------------------------------------------------------------------// void uart0_putc(char c) { while(!(U0LSR & 0x20)); // Wait until UART0 ready to send character U0THR = c; // Send character } //-----------------------------------------------------------------------------// //--------------- Function for send string via UART0---------------------------// //-----------------------------------------------------------------------------// void uart0_puts(char *p) { while(*p) // Point to character { uart0_putc(*p++); // Send character then point to next character } }
My main file
******************************************************************************************* #include <LPC214x.H> /* LPC21xx definitions */ #include <stdio.h> /* prototype declarations for I/O functions */ #include "Serial.h" int b=0; int temp; char ch = '\0'; int main (void) { /* execution starts here */ uart0_init(); // Initialize UART0 while (1) { /* An embedded program does not stop */ if(b) { uart0_putc(ch); b=0; } } }
My serial.h file
#ifndef _serial_ #define _serial_ void uart0_getkey(void) __irq; void uart0_init (void); void uart0_putc (char); void uart0_puts (char *); void init(void); extern int b; extern int temp; #endif
I take it you haven't read the user manual for the processor?
The compiler/linker can't produce a vector table outside the address range you give it to play with. What is your view on this issue after having read about memory remapping in the processor user manual?
Thank you, I have solved my problem.
I have one question about interrupt.
help me..
If I have taken three IRQ interrupts, VICVectAddr3 = ext2 int VICVectAddr5 = uart0 VICVectAddr7 = rtc
If program is in VICVectAddr7, and at that time if other high priority interrupt come,
THAN MY PROGRAM EXECUTE VICVectAddr7 ROUTINE AND GOTO ANY OTHER HIGH PRIORITY INTERRUPT OR WILL GO INSTANTLY WITHOUT EXECUTE LOW PRIORITY INTERRUPT ??
If you want nested interrupts, then you should start googling for that - Keil have a number of articles that are important readings. Normally, the processor will first have to finish the low-prio interrupt and exit before the processor will respond to the next interrupt.
The VIC may prioritize interrrupts. But the ARM processor core only have "interrupt" and "fast interrupt". So the core will not magically understand any higher interrupts playing with the interrupt signal.
