Dear All, I have implemented flash file system on LPC1768. Creating, writing and reading files successfully. If i try to open a file in read mode, a file that doesnt exist, then the controller goes into hardfault which is forced from precise bus fault error.
So, to stop my program from trying to read a file that doesnt exist, i used ferror as shown in the code below. But i m still getting an hardfault.
parse_proto_name(LOAD_PROTOCOL); //Get Protocol Name FileName = (char*)gProtocolName; fProtoName = fopen (FileName,"r"); //Open the File for reading if(ferror(fProtoName)) return; //Return if an error occured while trying to read a file. while(!feof(fProtoName)) { temp = fread(&gTx0Buf[dtcntr], sizeof(char), 640, fProtoName);//Copy the file contents into TxBuf } fclose(fProtoName);
Details of variables
// Global Variables uint8_t gProtocolName[32]={0}; //To store the name of the protocol received from the display FILE *fProtoName; //Local Variables uint8_t dtcntr;//data counter
Am i expecting too much from ferror & foef?
