pll and clock setup issue on mcbstm32c
hey,,
>>i want to use usart-2 peripheral on MCBSTM32C and i realised the baud rate set was incorrect, (inspite of right calculations) which was because of the incorrect plck-1 (=112.5Mhz, which should be 36Mhz),, also plck-2 and hclk, system clock set are wrong.
>>for clock setup i'm using SystemInit function from system_stm32f10x_cl.c (i took this from keil's example program.)
>>so i tried running an example prog from keil on the board. i flashed Blinky_ULp into the board ,, but still the same problem of incorrect pclk-1, pclk-2, hclk, sysclk etc persisted,,
please help.. i cant understand why example codes work incorrectly !!!!!
