hi all,
i am using the embedded artist development board and i have dump the ethernet code which is compatible for development board it is working fine.
in development board the default device address is mentioned as 0x0100 in code. if we try to change the device address then its not working.
we have developed the same ethernet hardware for other board and we dump the ethernet code its not working....... we are using the LAN8720 to interface the ethernet.
so i am suspecting the default device address. how to find the device address for ethernet. its getting connected but data transfer is the problem.....
please help me how to debug and test the ethernet.
thank you in advance.
