When building from the command line or another IDE is there a way to have uVision not rebuild the whole project.
As part of an automated build it is a good thing to do the complete rebuild but I have been looking at eclipse as an alternative IDE. This does work but the build takes a few minutes each time rather than just seconds when doing a build after a small change in uVision itself.
Currently I am using a simple .bat file
echo Starting Build.bat C:\Keil\UV4\uv4.exe -r EFM32_Main_MCU.uvproj -o buildOutput.txt type buildOutput.txt
Any suggestions?
Thanks Stephen
IDE-Version: µVision V4.23.00.0 Copyright (C) 2011 ARM Ltd and ARM Germany GmbH. All rights reserved.
License Information: Stephen Robertson Spacelabs Healthcare LIC=IK125-D0D23-RZKSN-W8V2U-79FIV-8CHFZ
Tool Version Numbers: Toolchain: MDK-ARM Standard: 4 user Version: 4.23 Toolchain Path: C:\Keil\ARM\BIN40 C Compiler: Armcc.Exe V4.1.0.894 Assembler: Armasm.Exe V4.1.0.894 Linker/Locator: ArmLink.Exe V4.1.0.894 Librarian: ArmAr.Exe V4.1.0.894 Hex Converter: FromElf.Exe V4.1.0.894 CPU DLL: SARMCM3.DLL V4.23 Dialog DLL: DCM.DLL V1.4.0.0 Target DLL: Segger\JL2CM3.dll Dialog DLL: TCM.DLL V1.4.0.0
You could create a traditional Makefile completely skipping the IDE and instead have the Makefile invoke the assembler, compiler and linker directly.
