Please guide me.... I done small project bt not work properly.... project- i wanna 1 square wave having count 0 to 12000 which depend on external ADC and 5K Resistor pot.according vary the 5k pot then change the count pulse like pot is min position then count is 0 and pot is max positionin count is vary......
I do hardware but how to write code.....
I do hardware but how to write code you bring up an editor and enter your statements then you uise a compiler or assembler and linker to convert to machine language then you download the code then you debug
blog.antronics.co.uk/.../
I hardly ever write code by opening an editor and entering my statements. Starting from a blank slate is inefficient at best.
Instead, I search for example code that does some basic thing, even a "hello world" example from an IDE evaluation kit is good because the project already compiles, links, loads onto a known-good target and runs.
I wouldn't recommend starting to write software for your prototype hardware; start with an evaluation kit's simple example program, then get known good software to run on your as-yet-unproven prototype hardware. Modify the code to blink an LED as a good starting point - you did put an LED / resistor on one of the port pins of your prototype, right?
