Hi I want to ask you guys for help. Today I read the RL-ARM User Guide to start with the RTX RTOS. I don't know how to get a working "RTX_Config.c" for the LCP1768 controller. Would you guys be so kind to give me a hint how to open the configuration wizard to create such a file. I use uvision4 but cannot find any clues in the ides help file. When i search the directory in my programm folder and try to import one of the existing ones. There are only rtx files for serval controllers but not for the one i use.
Thank you for your attention
ben
Maybe check your Keil directory to see if you have something like:
C:\Keil\ARM\Boards\Keil\MCB1700\RTX_Blinky startup_LPC17xx.s system_LPC17xx.c RTX_Conf_CM.c
C:\Keil\ARM\Startup\NXP\LPC17xx
All Cortex-M3 have the same [systick timer] for RTOS.
