serial communication problem
sir.,
i wrote the following code in keil compiler., but eventhough i didnt specified while loop.,the code is executing in infinite loop. may i know y ?
my code:
#include <reg51.h>
void main()
TMOD = 0x20;
SCON = 0x50;
TH1 = 0XFD;
TR1 = 1;
TI = 1;
printf ("Hello World\n\r");
TI=0;
  • What do you think happens when the program leaves main()?
    Do you think there are some command line prompt that will show up, waiting for a program command to execute?
    An embedded application using the standard Keil startup files are never expected to exit. In this case, the code will restart again and again - but having a main() that exists is int this specific case not allowed. Another version of the Keil tools could just as well do something else - hang after end of main() or run random instructions found in the memory.
