check it out
hey i made a code for graphic lcd for connect that with lpc2148. nd there is not an error in that code. nd code debug in gpio port 1. bt i cant got the connection of pins. the problem is on which pin of glcd i have to coonect the pin of lpc2148..
my code is atteched below..
#include <LPC214X.H>
unsigned char font[] = {
0x00, 0x00, 0x00, 0x00, 0x00,// (space)
0x00, 0x00, 0x5F, 0x00, 0x00,// !
0x00, 0x07, 0x00, 0x07, 0x00,// "
0x14, 0x7F, 0x14, 0x7F, 0x14,// #
0x24, 0x2A, 0x7F, 0x2A, 0x12,// $
0x23, 0x13, 0x08, 0x64, 0x62,// %
0x36, 0x49, 0x55, 0x22, 0x50,// &
0x00, 0x05, 0x03, 0x00, 0x00,// '
0x00, 0x1C, 0x22, 0x41, 0x00,// (
0x00, 0x41, 0x22, 0x1C, 0x00,// )
0x08, 0x2A, 0x1C, 0x2A, 0x08,// *
0x08, 0x08, 0x3E, 0x08, 0x08,// +
0x00, 0x50, 0x30, 0x00, 0x00,// ,
0x08, 0x08, 0x08, 0x08, 0x08,// -
0x00, 0x30, 0x30, 0x00, 0x00,// .
0x20, 0x10, 0x08, 0x04, 0x02,// /
0x3E, 0x51, 0x49, 0x45, 0x3E,// 0
0x00, 0x42, 0x7F, 0x40, 0x00,// 1
0x42, 0x61, 0x51, 0x49, 0x46,// 2
0x21, 0x41, 0x45, 0x4B, 0x31,// 3
0x18, 0x14, 0x12, 0x7F, 0x10,// 4
0x27, 0x45, 0x45, 0x45, 0x39,// 5
0x3C, 0x4A, 0x49, 0x49, 0x30,// 6
0x01, 0x71, 0x09, 0x05, 0x03,// 7
0x36, 0x49, 0x49, 0x49, 0x36,// 8
0x06, 0x49, 0x49, 0x29, 0x1E,// 9
0x00, 0x36, 0x36, 0x00, 0x00,// :
0x00, 0x56, 0x36, 0x00, 0x00,// ;
0x00, 0x08, 0x14, 0x22, 0x41,// <
0x14, 0x14, 0x14, 0x14, 0x14,// =
0x41, 0x22, 0x14, 0x08, 0x00,// >
0x02, 0x01, 0x51, 0x09, 0x06,// ?
0x32, 0x49, 0x79, 0x41, 0x3E,// @
0x7E, 0x11, 0x11, 0x11, 0x7E,// A
0x7F, 0x49, 0x49, 0x49, 0x36,// B
0x3E, 0x41, 0x41, 0x41, 0x22,// C
0x7F, 0x41, 0x41, 0x22, 0x1C,// D
0x7F, 0x49, 0x49, 0x49, 0x41,// E
0x7F, 0x09, 0x09, 0x01, 0x01,// F
0x3E, 0x41, 0x41, 0x51, 0x32,// G
0x7F, 0x08, 0x08, 0x08, 0x7F,// H
0x00, 0x41, 0x7F, 0x41, 0x00,// I
0x20, 0x40, 0x41, 0x3F, 0x01,// J
0x7F, 0x08, 0x14, 0x22, 0x41,// K
0x7F, 0x40, 0x40, 0x40, 0x40,// L
0x7F, 0x02, 0x04, 0x02, 0x7F,// M
0x7F, 0x04, 0x08, 0x10, 0x7F,// N
0x3E, 0x41, 0x41, 0x41, 0x3E,// O
0x7F, 0x09, 0x09, 0x09, 0x06,// P
0x3E, 0x41, 0x51, 0x21, 0x5E,// Q
0x7F, 0x09, 0x19, 0x29, 0x46,// R
0x46, 0x49, 0x49, 0x49, 0x31,// S
0x01, 0x01, 0x7F, 0x01, 0x01,// T
0x3F, 0x40, 0x40, 0x40, 0x3F,// U
0x1F, 0x20, 0x40, 0x20, 0x1F,// V
0x7F, 0x20, 0x18, 0x20, 0x7F,// W
0x63, 0x14, 0x08, 0x14, 0x63,// X
0x03, 0x04, 0x78, 0x04, 0x03,// Y
0x61, 0x51, 0x49, 0x45, 0x43,// Z
0x00, 0x00, 0x7F, 0x41, 0x41,// [
0x02, 0x04, 0x08, 0x10, 0x20,// "\"
0x41, 0x41, 0x7F, 0x00, 0x00,// ]
0x04, 0x02, 0x01, 0x02, 0x04,// ^
0x40, 0x40, 0x40, 0x40, 0x40,// _
0x00, 0x01, 0x02, 0x04, 0x00,// '
0x20, 0x54, 0x54, 0x54, 0x78,// a
0x7F, 0x48, 0x44, 0x44, 0x38,// b
0x38, 0x44, 0x44, 0x44, 0x20,// c
0x38, 0x44, 0x44, 0x48, 0x7F,// d
0x38, 0x54, 0x54, 0x54, 0x18,// e
0x08, 0x7E, 0x09, 0x01, 0x02,// f
0x08, 0x14, 0x54, 0x54, 0x3C,// g
0x7F, 0x08, 0x04, 0x04, 0x78,// h
0x00, 0x44, 0x7D, 0x40, 0x00,// i
0x20, 0x40, 0x44, 0x3D, 0x00,// j
0x00, 0x7F, 0x10, 0x28, 0x44,// k
0x00, 0x41, 0x7F, 0x40, 0x00,// l
0x7C, 0x04, 0x18, 0x04, 0x78,// m
0x7C, 0x08, 0x04, 0x04, 0x78,// n
0x38, 0x44, 0x44, 0x44, 0x38,// o
0x7C, 0x14, 0x14, 0x14, 0x08,// p
0x08, 0x14, 0x14, 0x18, 0x7C,// q
0x7C, 0x08, 0x04, 0x04, 0x08,// r
0x48, 0x54, 0x54, 0x54, 0x20,// s
0x04, 0x3F, 0x44, 0x40, 0x20,// t
0x3C, 0x40, 0x40, 0x20, 0x7C,// u
0x1C, 0x20, 0x40, 0x20, 0x1C,// v
0x3C, 0x40, 0x30, 0x40, 0x3C,// w
0x44, 0x28, 0x10, 0x28, 0x44,// x
0x0C, 0x50, 0x50, 0x50, 0x3C,// y
0x44, 0x64, 0x54, 0x4C, 0x44,// z
0x00, 0x08, 0x36, 0x41, 0x00,// {
0x00, 0x00, 0x7F, 0x00, 0x00,// |
0x00, 0x41, 0x36, 0x08, 0x00,// }
unsigned char c;
unsigned char z=0;
void ctrloff()
{ IOSET1=0x00000000;
//DELAY FUNCTION
void delay(unsigned int j)
{ unsigned int i; for(i=0;i<j;i++);
void displayon()
{ ctrloff(); IOSET1=0x1C3F; delay(500); IOSET1=0x0C3F; delay(500);
void displayoff()
{ ctrloff(); IOSET1=0x1C3E; delay(500); IOSET1=0x0C3E; delay(500);
void setcolumn(unsigned char y)
{ if(y<64) { ctrloff(); c=y; IOSET1=0x1440 |(y&63); //0x40 represents Column 0 delay(500); IOSET1=0x0440 |(y&63); delay(500); } else { ctrloff(); c=y; IOSET1=0x1840|((y-64)&63); //0x40 represents Column 0 delay(500); IOSET1=0x0840|((y-64)&63); delay(500); }
void setpage(unsigned char x)
{ ctrloff(); IOSET1= 0x1CB8|x; //0xb8 represents Page 0 delay(500); IOSET1= 0x0CB8|x; //0xb8 represents Page 0 delay(500);
//Function to Scroll Strings
void setstartline(unsigned char z)
{ ctrloff(); IOSET1=0x1CC0|z; //0xc0 represents Line 0 delay(500); IOSET1=0x0CC0|z; //0xc0 represents Line 0 delay(500);
void lcddata(unsigned char *value,unsigned int limit)
{ unsigned int i; unsigned char v; for(i=0;i<limit;i++) { if(c<64) { v=value[i]; IOSET1=0x1500|v; delay(500); IOSET1=0x0500|v; delay(500); c++; } else { setcolumn(c); IOSET1=0x1600|v; delay(500); IOSET1=0x0600|v; delay(500); c++; } if(c>127) return; }
void lcdputs(unsigned char y,unsigned char x,unsigned char *str)
{ unsigned char i; unsigned int a; setcolumn(y); setpage(x); for(i=0;str[i]!=0;i++) { a=(*(str+i)-32); a*=5; lcddata(&font[a],5); }
void clrlcd()
{ unsigned char i,j; for (i=0;i < 8;i++) { setpage(i); setcolumn(0); for (j= 0 ;j < 128; j++) lcddata(&z,1); }
unsigned char ar0[]="*************** ";
unsigned char ar1[]="BJP";
unsigned char ar2[]="CNG";
unsigned char ar3[]="************** ";
int main()
{ unsigned char i;
displayon(); setcolumn(0); setpage(0); lcdputs(0,1,ar0); lcdputs(0,2,ar1); lcdputs(0,3,ar2); lcdputs(0,4,ar3); delay(65000); delay(65000); for(i=0;i<5;i++) { displayoff(); delay(65000); displayon(); delay(65000); delay(65000); } i=0; while(1) { setstartline(i++); //Function to Scroll Strings delay(40000); }
