__C51__ undefined in uV4?
I wrote and debugged a project on a workstation running uV3
(V3.30a) a while back. It contains a file that must be
shared with other (von Neumann) processors that do not use
Keil development tools and contains a pre-processor
construct for the definition of an object:
  #if defined(__C51__)
    struct unsMsgSpec const code sysParmTable[] = {
  #else
    struct unsMsgSpec const      sysParmTable[] = {
  #endif
that eliminates the non-ANSI reserved word when running on
non-Keil translators.
This same macro is used to declare the object in a header
file:
    extern struct unsMsgSpec const code sysParmTable[];
  #else
    extern struct unsMsgSpec const      sysParmTable[];
  #endif
The source file that defines the object and the header that
declares it are in the parent directory, beneath which are
project directories for the several micros that must co-
operate to run this embedded device.
The source module that references the 'sysParmTable[]'
object pulls in the same header file:
  #include "..\UnistarProtocol.h" /* CAN queries      */
from its parent directory. As coded, it builds and links
without error or warning on uV3.
I am attempting to hand it off to a co-worker who has uV4
(V4.60.6.10) on another workstation. During the link step of
the build, this object generates an error:
*** ERROR L103: EXTERNAL ATTRIBUT DO NOT MATCH PUBLIC
    SYMBOL:  SYSPARMTABLE
    MODULE:  .\Debug\UnistarProtocol.obj (UNISTARPROTOCOL)
When I look at the pre-processor output for this object (in
the module where it is defined), I see:
and
whereas, in the module where it is referenced, I see:
It appears that the definition of __C51__ has become
context-sensitive in uV4. Am I missing something?
Gary Lynch    printf("lynchg%cstacoenergy%ccom", 55+9, 55-9)
  • Unrelated to the existence of __C51__ but one thing to consider when using the preprocessor to add/strop "code" is to write:
        #define CODE code
    #else
        #define CODE
    #endif
    Then you can have variables like:
    struct unsMsgSpec const CODE sysParmTable[] = {
    So no need to duplicate the line. So only one place to change if you change the name of the data type or the name of the variable.
  • Cancel this request!
    The problem was an older workaround to the same problem that I failed to remove when I created the __C51__ workaround. My apologies.
