RTX and bootloader for ADUC7126
Hello all,
I have a simple bootloader that only jumps to the main app at this point. The app is using RTX and currently stuck at os_sys_init(). I have read in other threads to define RAM_INTVEC REMAP RAM_MODE under Target Options > Asm. It still didn't work when I did that. I noticed in my startup file, it has:
; Copy Exception Vectors to Internal RAM and Remap Memory
;  (when Interrupt Vectors are in RAM)
                IF      :DEF:RAM_INTVEC
                ADR     R8, Vectors         ; Source
                LDR     R9, =0x00010000     ; Destination
                LDMIA   R8!, {R0-R7}        ; Load Vectors
                STMIA   R9!, {R0-R7}        ; Store Vectors
                LDMIA   R8!, {R0-R7}        ; Load Handler Addresses
                STMIA   R9!, {R0-R7}        ; Store Handler Addresses
                LDR     R0, =MMR_BASE
                MOV     R1, #1
                STR     R1, [R0,#REMAP_OFFSET]
                ENDIF
but there are no references to REMAP or RAM_MODE. I saw in the startup file for LPC2300, there is a section for REMAP and RAM_MODE (listed below) but don't think it's meant for ADUC7126 since os_sys_init() still hangs when I added the code snippit.
; Memory Mapping (when Interrupt Vectors are in RAM) ---------------------------
MEMMAP          EQU     0xE01FC040          ; Memory Mapping Control
                IF      :DEF:REMAP
                LDR     R0, =MEMMAP
                IF      :DEF:EXTMEM_MODE
                MOV     R1, #3
                ELIF    :DEF:RAM_MODE
                MOV     R1, #2
                ELSE
                MOV     R1, #1
                ENDIF
                STR     R1, [R0]
                ENDIF
Another thread pointed me to check the processor mode. How do I check for the processor mode of the bootloader and app? Any advice would be appreciated. Thanks!
