I want to interface RF transmitter and receiver with 80v51 uc. which is the best suited trasmitter and receiver ic for 89v51 uc ? and is der any way to trasnmit data by encryptying it ? i need help . . thank u .
first, this must be the most descriptive subject yet
which is the best suited trasmitter and receiver ic for 89v51 uc ? the one that fit your app (distance, power, ...)
is der any way to trasnmit data by encryptying it ? no, but you can encrypt the data before tansmitting it
Let's see now. You probably think you are being clever by trying to encode your question, but you have failed miserably. You are an idiot. Rest assured that whatever you think you know, I know far more and will always be able to exhibit the superiority even when it is clearly not justifiable or even remotely true. I will not waste any more time on you. Goodbye.
RC;
First ignore the stupid jerks on this forum. I truly wish that Keil had a moderator on this forum.
After my rant I suggest that you look at the CC253x series of devices from Texas Instruments. They have the improved versions of the 8051 in the chips. They also have RF transceivers that interface to any MCU supporting SPI. Most of the IC vendor have similar devices.
You did not mentioned what frequencies that you need to support. Most of the IC devices that support the 2.5GHz band will have built-in encryptyion abilities. Some of the sub-gigahertz also have encryption.
Please ignore spelling errors. I have one eye bandaged and can't see very well out of the other eye.
http://www.lvr.com for some info and tutorials.
http://www.ti.com http://www.silabs.com
rgds,
Bradford
thanks for the help . .
i'm new to this field . i just made a 89v51 programmer kit which can be programed using hyper terminal using com port
i want to make RF Tx and Rx which can be interfaced with 89v51
i have heard of HT12E and HT12D RF decoder encoder module. can u please help with this module ?
thank u
i want to use 450 MHz or 900 MHz frequency.
Sorry. I'm know nothing of these modules. Go to the module data sheets to determine the interface signals. Go to the 80V51 data sheets to see if the device supports the type of interface the modules require.
I don't know what country you are located but I suggest that you become well aware of the laws of RF in your country. Frequency bands allowed in one country may be forbidden in another country.
Most of the newer RF transceiver will support what is called Hi Band or Lo Band. For example the TI CC1100 transceiver will tune via internal registers from 380MHz to 960MHz. Your band restriction then would be the antenna design.
As I read over your email I now realize that you might be looking for a complete RF module already wired and ready to go. Look at Xbee modules for a completed RF module design. Also you can download schematics of their modules to see if they fit your application.
Again, I suggest that you vist the website of the device vendors such as Silabs or TI even though you may not use their devices. They have a lot of information and tutorials on these web sites.
thank you for helping me
