Hi, I have some code that hangs periodically, but do not know how to setup the watchdog control register to initialise for processor reset and reset timeout. I also need to know how to reset the watchdog in normal use to prevent a reset.
If I can get the watchdog running I can work on the problem that causes the latch up later.
Any help will be very much appreciated - using Keil Realview -
Regards Rob aspey@alumni.caltech.edu
What does the Datasheet say?
Have you searched the manufacturer's website for examples, application notes, etc...?
I have some code that hangs periodically, but do not know how to setup the watchdog control register to initialise for processor reset and reset timeout. It is good to have a fire extinguisher, but you do not want to have to use it.
