Hi all,
The base paper which I took for my final semester project is "Self-Sustaining, Efficient and forward-secure cryptographic schemes for unattended wireless sensor networks".
In this paper, it comprises of 4 stages,
1. Key generation 2. forward-secure and aggregate signature generation 3. trapdoor release 4. signature generation and verification.
And the final scheme is called ""Hash based sequential aggregate forward secure scheme".
In which tool this steps can be implemented easily and how can I start wiith?
If anyone has some idea, please help me.
Well, you read the paper, and you decided that it was a suitable basis for your project - so don't you have any idea?!
hi sir,
Really I could't get the way to implement this paper.. I've read it many times.
I'm confused in simulating and evaluating the concepts. Kindly help me
Maybe take one step back then and check if you can switch to another project. Because your project requires that _you_ collect quite a lot of information about information processing, encryption, key escrowing, ...
Then you need to go to your tutors now to discuss your options!
Hopefully, it is not too late for you to switch to a project which is within your capabilities...
You mean this:
Self-sustaining, efficient and forward-secure cryptographic constructions for Unattended Wireless Sensor Networks
Attila Altay Yavuz, Author Vitae, Peng Ning
Cyber Defense Laboratory, Department of Computer Science, North Carolina State University, Raleigh, NC 27695, USA
www.sciencedirect.com/.../S1570870512000479 ?
yes Sir. That paper only. Please could me help me.
If you're so stuck that you can't even make a start, then you really need to be talking to your tutors about that!
I'm facing a problem to proceed with. I understood key generation part and hashing schemes and implemented it. but how to prove the paper results? And how can i make enhancement.
That, surely, is the work of your project?!
yes. I understood in such a way that three categories of key generation and hashing schemes applied in the paper.
Please could you brief it in terms of implementation and enhancement parameters.
a good way to enhance paper is to get some felt pens, draw patterns around the edge and sprinkle some glitter all around.
works for my daughter.
(and before you say "what you on about?", consider why you think a forum for Keil Tools is likely to get the desired answer)
That part is ok. but still i'm looking for a good parameter to enhance.
And if you could see that paper title, please tell me a way to implement fully and evaluate results.
The only way you can improve, is by first understanding everything written in that paper. You obviously don't. So you are seriously stuck. Get another task, or start some serious reading for the next week or two.
The web can't help you by force-feed the knowledge you are lacking. And it would be cheating to have someone on the net do the work for you. But maybe you find that cheating isn't really a problem - that it is enough that you pass your exam even if you haven't any idea why or how? So - would you describe yourself as a cheater or as a honest person?
This is something irrelevant. Hope you dint understand my query first.
I dont need any coding or ideas from someone. I dont like to do such stupid things.
I need some guidance to proceed in each step. thats it. I got perfect idea, (just like a procedure) from a good guide.
I could make it in my own style with better output.
Thank you all for your support.
That's what your tutors are for.
This forum is for discussing Keil tools & products: http://www.keil.com/forum/
It is not a free tutoring/mentoring service.
