Using Logic Analyzer
Hello
I want to use logic analyzer .
When i try to add signals of my GPIO
thats GPIOB (STM32) i get error message as Unknown signals
What can be added?
Could anyone let me know pls
  • Use the example Blinky_ULp from e. g. Keil\Arm\Boards\Keil\MCBSTM32F400.
    But for SWO trace there the ini file STM32_SWO.INI is not correct.
    Use the following INI file:
    FUNC void DebugSetup (void) {
      _WDWORD(0x40023830, _RDWORD(0x40023830) | 0x00000002); // RCC_AHB1ENR:   IO port B clock enable
      _WDWORD(0x40020400, 0x00000080);                       // GPIOB_MODER:   PB3 = Alternate function mode
      _WDWORD(0x40020408, 0x000000C0);                       // GPIOB_OSPEEDR: PB3 = 100 MHz speed
      _WDWORD(0x4002040C, 0x00000000);                       // GPIOB_PUPDR:   PB3 = No Pull-up/Pull-down
      _WDWORD(0x40020420, 0x00000000);                       // GPIOB_AFRL:    PB3 = AF0
    // <h> Debug MCU Configuration
    //   <o1.0>    DBG_SLEEP      Debug Sleep Mode
    //   <o1.1>    DBG_STOP       Debug Stop Mode
    //   <o1.2>    DBG_STANDBY    Debug Standby Mode
    //   <o1.5>    TRACE_IOEN     Trace I/O Enable
    //   <o1.6..7> TRACE_MODE     Trace Mode
    //             <0=> Asynchronous
    //             <1=> Synchronous: TRACEDATA Size 1
    //             <2=> Synchronous: TRACEDATA Size 2
    //             <3=> Synchronous: TRACEDATA Size 4
    // </h>
      _WDWORD(0xE0042004, 0x00000027);  // DBGMCU_CR
    DebugSetup();                       // Debugger Setup
    ** Execute upon software RESET
    FUNC void OnResetExec(void)  {
      DebugSetup();
    And check the uVision Help file for uLINK pro - SWO debugging.
