For the first time in many years I need to simulate I/O by using a signal function - specifically - toggle the T0 pin (P1.2 on a LPC915) as I am using Timer 0 as a counter. I have two problems, best described by a segment of code stripped down to try to find the fault.
SIGNAL void toggle_T0 (void) { while(1) { PORT1 |= 0x04; twatch (0.2); PORT1 &= ~0x04 twatch (0.2); } } void main (void) { }
Even with this "nothing program" I get : error C129: missing ';' before 'void' with a line number that points to the signal declaration. Also, what is the correct name for the VTREG that defines the pins of Port 1?
Thanks Andrew. The first link on your reply told me everything I needed to know.
