First I'd like to say that I'm new to uVision and to the stm32F4-Discovery board.
I'm currently using uVision with the stm32F4-DISCOVERY board and expansion pack which includes a camera. I found the camera driver online but I'm running into trouble when I try to download it to flash memory on the discovery board using a USB cable. Both projects will compile without issue, and I can download an example project without issue, but when I switch to the camera driver project it gives me two errors.
The first one says: "No ULINK Device Found." And the second says: "Error: Flash Download Failed - Target DLL has been canceled."
Can someone please help me with this problem? I can't figure out why one project works fine but the other runs into problems.
Thanks, Jacob
Check the options of the camera project.
That worked perfectly! I was under the impression that the options were not project specific.
Thanks for the help!
It would be very helpful to me and others that view this thread if you could tell us what exactly you changed to fix this issue. Thanks!
