I am trying to convert this simple code to SDCC (due to chaninging to Linux):
// main.c #include <t89c51cc01.h> #include <stdio.h> #include <lcd.h> // my own lcd header file int i = 0; void main() { char txt[17]; lcd_init(); while (1) { lcd_home(); sprintf(txt, "Zahl: %i", i); lcd_send_text(txt); } } void gelb() interrupt 0 { i++; }
The "lcd.h" header:
// LCD header file #ifndef _lcd_H_ #define _lcd_H_ #define DIS_ON_1 2 // to be continued void lcd_init(); void lcd_display(); void lcd_dis_on(unsigned char i); void lcd_dis_off(); void lcd_store(); void lcd_clear(); void lcd_send_char(unsigned char c); void lcd_send_text(char *t); void lcd_position(unsigned char p); void lcd_home(); void lcd_wait(); void lcd_sec(unsigned char i); void lcd_msec(unsigned char i); #endif // _lcd_H_
With Keil, all worked fine. With SDCC, following code:
// main.c #include <mcs51/8051.h> #include <stdio.h> #include <lcd.h> int i = 0; void main() { char txt[17]; lcd_init(); while (1) { lcd_home(); sprintf(txt, "Zahl: %i", i); lcd_send_text(txt); } } void gelb() interrupt 0 { i++; }
I get the following errors:
?ASlink-Warning-Undefined Global '_lcd_home' referenced by module 'main' ?ASlink-Warning-Undefined Global '_lcd_init' referenced by module 'main' ?ASlink-Warning-Undefined Global '_lcd_send_text' referenced by module 'main'
It creates the .ihx file, tho...
Can anyone of you figure out what's wrong? I hope this is the right place to ask...
Thanks in advance =)
