IAP failure on LPC1114/301
My IAP functions update the flash, but toward the end of each programmed block there is always inconsistent data at the same offset from the beginning of the block (mostly): it differs from the data provided by the buffer in internal RAM but the IAP function "copy RAM to flash" returns no error (and yet - the programmed code is corrupt)! My chip is clocked by IRC, 12[MHz] (no PLL). I tried different IAP blocks sizes (using 256 now but it does not matter), clock speeds - to no avail.
What could be the cause of this?
